6 members (MikeStone1953, KEVINSKI, Jay R, crenwelge, Hotrod Lincoln, delwrench), 330 guests, and 5 robots.
Topics128,159
Posts1,057,027
Members48,460
i have a 55 chevy 4400 with the inline 6 in it, and was hoping to put a 305 v8 in it. will it bolt to my original 4 speed.
It will with the right bellhousing.You will also need the front mounts.
_____________
Floyd
If we choose being kind over being right,we will
be right every time.
Knowledge is a poor substitute for experience.
Remember what is precious to another, may not be to you, but it
is precious nonetheless.
1948 Chevy 2-Ton
any idea what they call this 4 sp tranny
same '47-'67 ... you'll need an aftrmarket engine mount crossmember and a fan shroud, otherwise it's a pretty straightforward swap
The original 4-speeds are known as the "SM420" with a Granny Gear first gear and 1:1 4th gear ratio, they are almost bullet proof. The Small Block Chevy (SBC) V8 engine was optional in 1955, so your 305 SBC will bolt in. It won't give you any real speed inprovement (3000 RPM is still 3000 RPM regardless of what engine is turning it), but will give you more power. You will also need a deep fan shroud.
I have a 1956 8400 that started life with the 265 V8 and now has a 350 SBC V8.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Try this link they have great info and parts if you can't find old ones to use.
www.advanceadapters.com
Stovebolt Gallery
1952 Chevy 3100
1953 Chevy 4400
1965 Nova
Pics on Photobucket
I'm actually looking at doing the same thing with my '69 C50, only a '69 307 instead of a 350. It has an oil bath 350 right now, but it's VERY tired and the 307 doesn't have 2k miles on the rebuild w/327 heads and a 4bbl. I'm hoping that it'll bolt up to the SM420 that's in it currently.
Bryan
Equal opportunity truck employer
2x - Ford Superduties
'92 Toyota
'05 Silverado 1500
'69 C50 "Grumpy" 350/SM420 flatbed
thats what I am doing in my 55 1.5T berad truck.. originally had a 261 and the same 4 speed as mentioned above.. you need the 55-64 bell housing as they went to a bigger bearing retainer in 65. the flywheel wont work.. need one of them too.. also you can run your original friction disc. but depending on which flywheel you may need to get a different preassure plate. the fork should swap over as well..
Huh?
