2 members (Opelika Tom, Otto Skorzeny), 86 guests, and 1 robot.
Topics128,134
Posts1,056,402
Members48,441
#704449 12/18/2010 11:07 AM
I am restoring a 1963 Chevy c10 short bed step side. Although most of my mechanic work and body work is being done by someone I feel that I can customize the way I want. It would be nice if I did most of the work myself, it would save me a lot of money. I hope to have a show quality truck in a few years. At this point we have done the frame, and did some patch up inside the cab, my painter has painted the fire wall and the inside. The next step will be the mechanical work which will have lots of chrome, and from there, save some more money and move to the body work. Stay tune!! By the way want to change out the single headlight grill and the hood for the 1961 apache hood and grill to give my truck the apache look, will it work?
Welcome award, Sounds like a great project!! The hood and headlight/grille swap should not be a problem. Make sure you get the wiring harness from your donor truck for the four bulb setup.
glos55
Smokey 56
Smokey 56
Welcome!
Dan and Melina from MN. 1956 Chevy/GMC custom 1 Ton dually step side short box.
welcome to the bolt. I would leave the grill and hood as is but it is your truck..............we need some pix of this truck also.. enjoy the ride,
Fred n Mesquite
Redryder pix
My Hotrod
Welcome!!!!
Welcome to the Bolt. You came to the right place! There's lot's of knowledge and camaraderie here.
