| | | Forums66 Topics128,029 Posts1,055,417 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2009 Posts: 12 New Guy | | New Guy Joined: Dec 2009 Posts: 12 | 59 Apache 6cyl original. Speedo works in warm weather. When below 50 degrees won't come off zero. Any ideas | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | Remove the cable and clean it. Could be gritty lube in the housing. | | | | | Joined: Dec 2009 Posts: 12 New Guy | | New Guy Joined: Dec 2009 Posts: 12 | Thanks I'll try that but it looks like either way it should turn some in hot or cold weather. Works fine when warm. Thanks again for the reply... | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Could be dried up grease and gunk in the speedometer. | | | | | Joined: Feb 2010 Posts: 476 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 476 | If you don't want to remove the speedo take the cable out and shoot some WD40 with a straw in the speedo at the cable hook up | | | | | Joined: Dec 2009 Posts: 12 New Guy | | New Guy Joined: Dec 2009 Posts: 12 | Thanks for the imfo. Ill try the wd40 when I get home. In co. for a week. | | |
