Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
1 members (51sub), 187 guests, and 7 robots.
Topics128,288
Posts1,058,578
Members48,492
#704767 12/19/2010 7:26 PM
59 Apache 6cyl original. Speedo works in warm weather. When below 50 degrees won't come off zero. Any ideas
TruckOn #704769 12/19/2010 7:31 PM
Remove the cable and clean it. Could be gritty lube in the housing.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
Thanks I'll try that but it looks like either way it should turn some in hot or cold weather. Works fine when warm. Thanks again for the reply...
TruckOn #704902 12/20/2010 4:03 AM
Could be dried up grease and gunk in the speedometer.
Denny Graham #705101 12/21/2010 12:10 AM
If you don't want to remove the speedo take the cable out and shoot some WD40 with a straw in the speedo at the cable hook up
Thanks for the imfo. Ill try the wd40 when I get home. In co. for a week.
