3 members (MickeyP, Greg_H, GA Boy), 105 guests, and 3 robots.
Topics128,169
Posts1,057,035
Members48,458
#704584 12/18/2010 11:16 PM
Could someone please tell me if a '40 1 1/2 ton rear end will bolt right into a '36 1 1/2 ton low cab truck. Thanks
Welll...it measures up ok and Lou MacMillans web site gives me hope. Moving on, I have the ring and pinion out of the 40 rear end to change the 6.1 to 5.4 and can't find a source for the rivets in the pinion coupling. Would also like to find a pinion nut...Can anyone help with this ?
Have you tried "Big Flats Rivits"?
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
I guess I could use mild steel rod, that's easy. Do you have any "big flat rivets" that your not using. I'm more concerned about busting the locking tab off of the pinion nut and not having a decent solution to that. Plenty of you guys have done this before so I'm just looking for a bit of a heads up before I get into a mess.
Big Flats Rivits is a rivit company...do a google search for them, they sell rivits, sorry I wasn't clear on that.
Happy Holidays!
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Thanks Mike. I thought you were joking as they are in fact Big Fat Rivets. I'll give them a try.
Happy Holidays !
David
Hey David, that's Big Flats not Big Fat rivits. They are located in Big Flats, NY
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
I may have a NOS pinion nut. Will check but which rear end do you have?
Thanks. That's a bit of good news. Mine is HB 17724.
Thanks Mike. I checked them out but they don't really have what I need. Looks like I'm going to use some soft steel and use an old coupling to form one head and peen the other in place.
That number HB 17724 does not help me. Is it a 2 speed or single speed? Is the nut 1.25" thick 1 19/32" dia. x 16 ?
This is what the Chevy parts book states.
Do you know model 1940 truck it came from?
It is a single speed rear end and the nut does have those dimensions and thread count. I do not know the model of the truck that the rear end came out of. Thanks.
OK I have that nut NOS and I think I have the coupling rivets also. I will check later. E-mail me at [email protected] for more info.
Thanks. Will do.
