8 members (pauld, lumbersawyer, Gdads51, frogfarmer, J Lucas, carbking, Charles in CA, 1 invisible),
99
7
Mod | | | Forums66 Topics128,264 Posts1,058,358 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2010 Posts: 5 New Guy | | New Guy Joined: May 2010 Posts: 5 | is there diagrams ect, for installing halogen headlights in our trucks? i need it all,where to buy harnesses, ect | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | All you need to do is remove the old sealed beams & replace them with new Halegens. For best results you can put relay's in the circuits. If you have 4 high beams it is highly recommended to put a relay in at least the high beam circuit. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Oct 2010 Posts: 43 New Guy | | New Guy Joined: Oct 2010 Posts: 43 | anyone one know of a way to wire all 4 lights to dual-beam lights?
62' GMC SWB Fleetside
Why can't we just go back to the designs from when cars were unique and didn't all look the same?
| | | | | Joined: Aug 2010 Posts: 109 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 109 | I'm sure it can be done but I don't know what the highway patrol would think of it.
'65 C-10, 65 L-60, 65 C-80, 72 C-60 & and a bunch of old Chevy cars. Never time to do it right, always time to do it over.
| | | | | Joined: Oct 2010 Posts: 43 New Guy | | New Guy Joined: Oct 2010 Posts: 43 | id like to convert my 62 gmc to run all 4 headlights..and try to use the lamps from the chevy single light setup so i have low and high beam for all 4 not just 2..my thought is to take the light sockets out of a chevy from the same year and use those..not sure bout the harness though..
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | keilkravec - what would be the advantage? aren't all 4 of your lights on for high beam already? would all 4 lights be on low as well as high? how about the difference in bulb size between the 2 and 4 light systems?
Bill | | | | | Joined: Oct 2010 Posts: 43 New Guy | | New Guy Joined: Oct 2010 Posts: 43 | from what i understand its only the outside 2 lights on low and the inside 2 are high beams, the bulb size is a good question though..in all honesty its more for functionality seeing as i live out in tenn. in the valley..backroads are the norm so it helps to have extra lighting. on that note i remember seeing safari lights that were factory option and mounted on top of the bumper anyone know anything about those?
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | you haven't looked at how they work? on the 58/9s one pair is low beam, all 4 are on for high, I'd expect the same for the 60's .... only way to get 'extra' is add extra, like separate driving lights, or switch to halogens, no need to reinvent the wheel  Bill | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I think he wants to put low/high beams in both spots. IIRC they won't fit properly unless you change the buckets to all low/high(outer) style. You would have all four on "low" then. Any vehicle inspections in your area? Here you would be fine, you can drive anything that rolls, no inspections whatsoever... | | | | | Joined: May 2010 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 47 | | | | | | Joined: Oct 2010 Posts: 43 New Guy | | New Guy Joined: Oct 2010 Posts: 43 | 64fleetside- thats pretty much exactly what i'm wanting to do since i'm out int he woods and wanting to keep the truck Mostly original, but need extra lighting and dont want to go through the trouble of drilling in safari lights when i dont have to. And no we dont have any kind of inspections here haha i ran my 93 dakota open header for about 3 months (not the best thing for my heads) and drove enxt to many a police cruiser with nothin out of the ordinary..gotta love livin in the country!
| | | | | Joined: Dec 2008 Posts: 337 Shop Shark | | Shop Shark Joined: Dec 2008 Posts: 337 | The regulations for Tennessee motor vehicle lighting regulations can be found here, under Title 55 Motor and other vehicles, Chapter 9 Equipment – Lighting Regulations. http://www.michie.com/tennessee/lpext.dll?f=templates&fn=main-h.htm&cp=tncodeI don’t find anything in the code making all four headlamps operating on low beams illegal, but it might be an invitation to get pulled over by a cop who thinks you’re running high beams, or that thinks you have your high beams on and they’re too dim, and you would no doubt be flashed by other motorists that just count the number of illuminated headlights. The technical problem in accomplishing this is that 4 headlight systems don’t work like two headlight systems. In a two headlight system each bulb contains a low and high beam filament. When the low beam filament is on, the high beam filament is off. When the high beam filament is on, the low beam goes out. In a four headlight system, the high beam lamps produce all of the high beam light output (35,000 candlepower in a non-halogen bulb). http://www.napaonline.com/Search/Detail.aspx?A=LMA5001_0278278328&An=599001+101960+50030+2030093It is true the low beam bulbs have two filaments, but the brighter filament is what produces the low beam output (11,000 candlepower in a non-halogen bulb). The low beam lamps do not produce high beam output when switched to high beams. http://www.napaonline.com/Search/Detail.aspx?A=LMA4000_0278280245&An=599001+101960+50030+2030093On a four headlight system, when the high beam circuit is switched on, the brighter filament in the low beam lamps goes out just like in a two headlamp system. But rather than have the low beam lamps go dark, a dimmer filament is illuminated and acts like a marker light. This is why “headlight brighteners” work. When the high beams are switched on, these devices keep the low beams at full power, providing both distance and close up lighting on both 2 and 4 headlight systems. http://www.ronfrancis.com/prodinfo.asp?number=BJ-2Replacing the high beam headlights in a four lamp system with two more dual filament low beam lamps, will give you four low beam lamps. There will no longer be high beam light output available. When the high beam circuit is switched on, all four bulbs will switch to the dim filaments providing four nicely glowing marker lights. | | | | | Joined: Oct 2010 Posts: 43 New Guy | | New Guy Joined: Oct 2010 Posts: 43 | so in short its hardly possible without major re-wiring and fabrication?
| | | | | Joined: Dec 2008 Posts: 337 Shop Shark | | Shop Shark Joined: Dec 2008 Posts: 337 | The short answer is it isn't practical. Sorry, it sounds like an intriguing idea, but the technology doesn't work right.
Wiring would be very simple. The low beam headlights already have a low and high beam circuit. All that would be needed is the addition of two more wires running from the high beam circuit from the low beam lamps to the new dual filament high beam lamps.
But the only way I know of to get true low/high beam headlamps would be to switch all four bulbs to 7" lamps designed for a two headlamp vehicle. That would probably look pretty goofy, and would require fabrication of new mounts for the larger bulbs and modification to the grille. | | | | | Joined: Oct 2010 Posts: 43 New Guy | | New Guy Joined: Oct 2010 Posts: 43 | that was my thought for using something like the chevy lamps to achieve that effect and i knew wiring wouldnt be that much trouble..my only trouble spot is finding t-3 lamps that work like that in the size i need.
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Something you might consider instead of rewiring the lights would be to use some of the nower style hi outmup lighting, like the Silverstars from Silvania or possibly an hid style bulb. I'm running Slverstars in both of my trucks (single lamps) and also run in wooded areas similar to what you have. I almost never need to use the high beams.
Bill Burmeister | | |
