5 members (Gdads51, 52Carl, Woodcmiami, Gib70, 1 invisible), 80 guests, and 3 robots.
Topics128,060
Posts1,055,840
Members48,427
I need to remove the horn button on my '64 to determine what's wrong with my turn signal cancel but I can't find anything in the manual about how to remove it. I don't want to start prying on it and break something. Any advice will be appreciated.
thanks.
Jeff
'64 swb stepside (gone)
'57 1 ton
'53 phone truck
'59 swb
'46 1 1/2 ton
'68 swb gmc
Don't know about '64, but on my '65 it just pulls off...some rubber holds it on, I think.
cm
If you can't fix it with a hammer and screwdriver, you need a bigger hammer.
1965 Chevy C10
Thanks, that's probably it. I tried twisting it off but nothing happened.
'57 1 ton
'53 phone truck
'59 swb
'46 1 1/2 ton
'68 swb gmc
There is a rubber surround on the back of the stock horn button on the '60-'66 Chevy/GMC standard steering wheels, which secures it on the wheel cup, via a "friction-fit". It can simply be pulled off, without damage to the rubber ring, horn button or wheel cup. When installing, a little WD-40 or dielectric grease will ease the process of replacing it or removing it in the future.
I am looking for a good diagram of whow the horn button and the turn light cam is put together, especially the 2 springs and 2 keepers in the turn light cam mechanism on my 62 chevy C20.
I have a scan of that I can e mail to u . I need your email address
Ken
Ken,
Can you also send the scan to me. I have had this question in my case as well. Thanks for assist. [email protected]
~ HB
1962 Chevrolet C10
1962 Suburban
Hey Ken -
Me too please?
[email protected]
Thank you an Happy Holidays!
Thom Masterson
I sent it out for you guys Sunday.2:53 pm
sorry ken. Just noticed my typo in the email address. If it is not too much to ask.... and I thank you in advance if you would send along the the graphic to my corrected address.
[email protected]
My column inner workings remains a mystery to me.
Hambone
~ HB
1962 Chevrolet C10
1962 Suburban
I did not receive it. The email address is kind of long. Again it's [email protected]
Thanks again and Happy Holidays!
Thom Masterson
I thought you spelled it weird.
Ken, If you are still there. It appears I can no longer find the exploded view of the steering column. Lost in my old computer I think. Can you send it long again. ([email protected])
Can anyone help me with continuity check of horn wiring. Horn works when shorted directly to battery. Installed all bits and pieces in steering wheel cap. But no horn. Tried shorting (but my method may have been incorrect) horn plate/cap with steering wheel off. No result.
I have a great horn and an additional H/L set to play with, but can't seem to figure it out.
HB
~ HB
1962 Chevrolet C10
1962 Suburban
