2 members (Gdads51, WICruiser),
84
Mod | | | Forums66 Topics128,268 Posts1,058,319 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 16 New Guy | | New Guy Joined: Dec 2010 Posts: 16 | I have a 1950 GMC 3/4 ton that we are renovating! I would like to add a brake booster but I cannot find a kit for a 3/4 ton. I understand the frames are different from a 1/2 ton. Does anyone know of a kit that would work and what modifications would be necessary to install it. Thanks, Erin
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | The Chevy 1/2 ton is around 11" wider than the 3/4 ton. If that is a fact with the GMCs it wouldn't matter for the break MCs or adding a booster. However my experience with brakes is after the 216 and 4spd tranny has been removed. A booster might interfere with the clutch. Someone with that experience will drop by soon I'm certain.
~Jim
| | | | | Joined: Apr 2010 Posts: 35 New Guy | | New Guy Joined: Apr 2010 Posts: 35 | I think you would be fine with this. I think you might have to modify something, as these didn't come with "boosters" so your lines and a possible crossmember fab might be the only other thing you need to do. Copy and past the link below, if you can't click on it. This is for drum/drum. I don't think you will have any problems using this with a GMC frame http://www.classicparts.com/1947-54-Power-Brake-Booster-Conversion-Drum_Drum/productinfo/71-903/ | | | | | Joined: Mar 2002 Posts: 9,116 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,116 | Somewhere it was mentioned in a post about an inline booster that you can get, sort of a modern day hydro-Vac. Maybe that would be of interest. | | |
