3 members (carbking, Rnl364, Oswald), 75 guests, and 3 robots.
Topics128,064
Posts1,055,860
Members48,428
#704259 12/17/2010 9:04 PM
k10
Offline
I want to mate up my 235 to a 200r4. Problem is I'm too cheap to get an adapter from the likes of Bendtsen's or Buffalo (actually I just can't afford it right now). How hard is it to make your own? Any schematics or how-to's somewhere here or online?
k10 #704306 12/17/2010 11:39 PM
ODSS Lawman
ODSS Lawman
Go get the part you cheap bastard..........
drive
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
SWEET #704325 12/18/2010 12:38 AM
k10
Offline
Definitely the pot calling the kettle black.
k10 #704326 12/18/2010 12:44 AM
If you can get the right size piece of aluminum, you could make your own. I have a one that was made for a th350 some years ago. You can lay out the overall size, the mounting holes and crank opening by using heavy paper to make a guide. Obviuosly you'll need the trans and bell housing to get the measurements. Then there is the question of getting it all to fit right. Some machining may be necessary.
Drew
DrewP #704374 12/18/2010 3:28 AM
Trial and error costs $$$$ in the end.
don stocker #704739 12/19/2010 5:54 PM
Well said, you'll find out a properly machined adapter is much cheaper then tearing up transmissions in the long run.
It may work great for 500 miles , but a homemade adapter isnt going to be close to centreline, and accuracy is everything.
You will wipe out trans bearings, not if, just a matter of when.
1946 Chevy 1/2-Ton
More pix on Photobucket
Sometimes I forget where I left myself....
andy46 #704864 12/20/2010 1:50 AM
Y
yar Offline
Y Offline
Come on guys, lets give him some encouragement. This is Stovebolt, not VCCA. When I took machining class in evening adult education the teacher told me "Anything you can imagine, you can build. All it takes is time". That gave me the confidence to take on some challenging projects.
The only critical part of this project is keeping the transmission input shaft and the engine crankshaft on the same axis. That can be easily accomplished by machining a hub-like fixture that bolts to the back of the crankshaft and has a rearward protruding transfer punch that contacts the adaptor plate as it is tightened up to the back of the engine. That will center punch the plate to establish the crankshaft and transmission axis point on the adaptor plate.
I have a 2004R in my street rod roadster but I forget what the front of it looks like because I installed it about 7 years ago. Anyway, a centering device can then be machined to fit the front seal area of the transmission and fit the crankshaft center previously located. When the trans is in contact with the adaptor plate with the transmission axis and crankshaft axis exactly matching, a transfer punch will locate the bellhousing bolt hole locations on the plate.
As for a "Properly machined adaptor" mentioned by Andy, a very good friend of mine bought an adaptor plate to mate a 2004R to his '63 Studebaker Avanti engine. It didn't even come close to being an accurate part and required major reworking by my friend before it could be used. He was very disappointed.
If K10 makes his own plate he will have a lot more bragging rights than he would have if he bought one. In fact if it works out, he would then be able to use it a pattern to make more for other people.
Ray
