3 members (Wickedbass, Nick in Manitou, JW51), 93 guests, and 2 robots.
Topics128,066
Posts1,055,876
Members48,428
Hey All On my continuing mission to get my truck on the road again I've hit a roadblock. I've managed to get the engine running, actually quite smoothly on full choke. My problem is when I step on the gas she hesitates, like it's choking it's self out. And when it warms up and I cut the choke it'll idle nich at reg speed for about a minute, then starts to idle down and back up a bit, then hesitates, and then dies. I've tried to adjust the carb but I still can't get it. any suggestions? It's a 235 with the stock 1BBL Rochester. Does anyone think I need to have the carb rebuilt? -Danny
Thanks,as always -Danny
1960 C-10 Stepside,Longbox
235,4spd 3.90 diff.
A rebuild will never hurt anything. When was the last time it was done? Do you have a filter on it?
Also: Rochsters from that era have a reputation for warping problems on the bowl cover thing. that may be something to check, too.
If thost two things don't help out, you may want to change ths subject on your post to mention carburetion or CarbKing so he can jump in here and render assistance.
Well It hasn't been rebuilt since I've had it and I've had it for about 4 months, though I know it sat for a a few years with min. drive time.
235,4spd 3.90 diff.
It should not run smoothly on full choke. You either have a vacuum leak or a problem with the carb, or the ignition timing (check the point gap) is way off.
A properly running 235 should start easily with slight choke and bog down quickly with full choke. Once it starts and runs for 30 or so seconds it should be able to idle with no choke at all.
Paint & Body Shop moderator
