3 members (WICruiser, 3B, GMCJammer51), 114 guests, and 3 robots.
Topics128,056
Posts1,055,796
#704184 12/17/2010 4:37 PM
Do I have pull the pinion gear to change the front seal on a chevey 1955 2nd series 1/2 ton rear end?
No, remove the drive shaft, remove the nut that holds the flange, and remove the seal. Install in reverse order. Put some light grease on the seal surface and the splines.
Fred
be careful reinstalling that you don't overtighten. There's a smash ring in there that sets your play.
TXredtruck you may want to look at it in the shop manual.
The online manual may do the trick for you.
A big Thanks to Keith Hardy for putting these on line.
http://chevy.oldcarmanualproject.com/
The torque specs should be in there to avoid what avette4me mentioned in his post.
Get a good impact gun to take the pinion nut off.
Yep Don, I've found that the only thing that will take them off if they've never been off is my 3/4" drive Earthquake impact.
And since ya mentioned Keith Hardy Alvin, might not hurt to bring up what ya did in the Greasy Spoon. And that is, that this might be a good time to put a little something in TOCMP Christmas stocking and lets not forget our hosts here at the Stovebolt. We've been using these resources all year long so lets all get in the Christmas spirit and play Santa Clause.
Merry Christmas to all you ‘Bolters,
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Good suggestion Denny. I need to do just that....
...and for those who may not know what TOCMP stands for it is:
THE ONLINE CHEVY MANUAL PROJECT.. where our friend Keith Hardy has so dilligently put these manuals on line. A major undertaking and a job he has done very well...so from me Keith, thanks and something will be in your stocking along with the Stovebolt.
