1 members (Paul Mullen), 109 guests, and 5 robots.
Topics128,271
Posts1,058,314
Members48,485
I have a 1950 GMC 3/4 ton that we are renovating! I would like to add a brake booster but I cannot find a kit for a 3/4 ton. I understand the frames are different from a 1/2 ton. Does anyone know of a kit that would work and what modifications would be necessary to install it.
Erin smile
Erin_Reaume #704148 12/17/2010 3:01 PM
The Chevy 1/2 ton is around 11" wider than the 3/4 ton. If that is a fact with the GMCs it wouldn't matter for the break MCs or adding a booster.
However my experience with brakes is after the 216 and 4spd tranny has been removed. A booster might interfere with the clutch. Someone with that experience will drop by soon I'm certain.
~Jim
BIG CHEVY 3600 #704432 12/18/2010 7:10 AM
9
9 Offline
I think you would be fine with this. I think you might have to modify something, as these didn't come with "boosters" so your lines and a possible crossmember fab might be the only other thing you need to do. Copy and past the link below, if you can't click on it. This is for drum/drum. I don't think you will have any problems using this with a GMC frame
http://www.classicparts.com/1947-54-Power-Brake-Booster-Conversion-Drum_Drum/productinfo/71-903/
51' 3100 s10swap, 350, 5 speed, patina
http://67-72chevytrucks.com/vboard/showthread.php?t=382481
49' GMC 3100 future project
55.1' chevy future project
54' 6400 chevy dump truck all original
63' c-10 future project
99 to Life #704543 12/18/2010 8:18 PM
Somewhere it was mentioned in a post about an inline booster that you can get, sort of a modern day hydro-Vac. Maybe that would be of interest.
1951 1 Ton Completed
