5 members (Lostbuthaulinass, Uncles51, Wayne67vert, Tronman, Hotrod Lincoln), 96 guests, and 2 robots.
Topics128,134
Posts1,056,410
Members48,441
Are the left and right tail lights interchangible?
Probably going to go with a roll pan with licence plate in the middle, and wont need the built in licence light on the left side, wondering if I can just get 2 rights and put them on both sides?
Buying them from Classic Industries most likely.
1950 3100 Project-just getting started
I used the round ones from a 54 on my 53, and also a 54 bumper and license plate bracket.
I want LED lights in mine. Can you buy the LED bulbs for a standard light?
~Jim
Duwem, My original style tail lights are interchangeable.
Big Chevy 3600 Yes, you can buy LED Bulbs to replace most any filament bulb now.
1952 Chevy 3100
More pictures in Photobucket
Doin better'n some an worse than others. Life's what ya make of it. FAMILY, GOD and COUNTRY. Love it or Leave it.
Speedway motors sells them.
Ex Hall Monitor
Ex Hall Monitor
Yes but you may be disappointed as I was at the amount of light they put out. Every 6v LED I found is a poor substitute for the incandescent bulb it replaces.
I wonder if 12v is much better.
~Jim
I think the license plate light,and left and right brackets are the only difference.
Tim
1951 3100 Chevrolet
Tims right,
The brackets are different
If Duwem is going to use this Bracket
It would have to be modified to accept the Right side lamp
The center hole on the driver’s bracket would have to be drilled out on the diagonal so the counduit will clear, But it could be done.
This is refering to aftermarket housings,
Good luck
I have no issues with my 12v LEDs they're a whole lot brighter than the incandescents.
More pix on Flickr.
Thinking I would use this bracket for the right side and get 2 right tail lights so I dont have the licence light on the left.
http://www.classicindustries.com/truck/parts/ct26686.html
Then I would lop off the licence mounting off the left side and just leave the tail light part.
Should work right?
Here's a pic of a after market tail lamps on a 50
pass side pic Note the outlet for the conduit.
drivers side pic
notice conduit outlet is different. Its higher on the housing,
It looks to me that if you want to mount a pass side housing on that drivers style bracket you will have to drill the bracket for the conduit outlet.
Good luck
Brothers Truck Parts has tail light brackets to do what you want. They remove the license plate part so you could use 2 right hand tail lights. I have the 12 volt led tail lights, they sure are brighter! I like them!
Did they come with the LED lights or did you get them at the FLAPS?
~Jim
They came with LED lights!
Duwem , the left tail light should have a little window at the bottom to shed light on the license plate while the right tail light will not have this feature. Funton
I saw an ad for these guys and since we did discuss taillights you might be interested in this link:
http://www.superbrightleds.com/cgi-bin/store/index.cgi?action=DispPage&Page2Disp=%2F1157.htm
~Jim
