0 members (), 57 guests, and 1 robot.
Topics128,051
Posts1,055,766
#704078 12/17/2010 3:28 AM
I can't seem to get my gauge to work. It reads full all the ti me.
terrygem #704089 12/17/2010 4:33 AM
Welcome to Stovebolt.com
You might want to post this question in the electrical forum.
Most likely the gauge is good and you have a bad ground at the sender/tank.
tclederman #704135 12/17/2010 1:01 PM
Z
Z Offline
Mine never changed either on my 66 C10. I pulled the sender from the tank and there was a broken wire inside the tank. The replacement sender is about 50 bucks.
zanemobile #704258 12/17/2010 9:03 PM
I have replaced both the sender and the gauge and still the gauge reads full. Iam guessing a ground problem?
terrygem #704268 12/17/2010 9:43 PM
terry - check continuity of the wire between the gauge and sender, could be an open circuit .... and welcome to the shop wink
squeeze #704273 12/17/2010 9:54 PM
Thanks, will do. Not likely get done till after christmas. Thanks again.
terrygem #706154 12/24/2010 9:55 PM
you need to drive it more
Redryder pix
My Hotrod
joker #706184 12/25/2010 12:33 AM
Welcome Terry, hope you get your gauge problem sorted out. Keep us posted on your progress.
Richard Morgan
1966 Chevy C10 LWB Stepside
More pix on Photobucket
