| | | Forums66 Topics128,054 Posts1,055,780 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 9 New Guy | | New Guy Joined: Dec 2010 Posts: 9 | I can't seem to get my gauge to work. It reads full all the ti me. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Welcome to Stovebolt.com
You might want to post this question in the electrical forum.
Most likely the gauge is good and you have a bad ground at the sender/tank.
| | | | | Joined: Aug 2010 Posts: 8 New Guy | | New Guy Joined: Aug 2010 Posts: 8 | Mine never changed either on my 66 C10. I pulled the sender from the tank and there was a broken wire inside the tank. The replacement sender is about 50 bucks. | | | | | Joined: Dec 2010 Posts: 9 New Guy | | New Guy Joined: Dec 2010 Posts: 9 | I have replaced both the sender and the gauge and still the gauge reads full. Iam guessing a ground problem? | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | terry - check continuity of the wire between the gauge and sender, could be an open circuit .... and welcome to the shop  Bill | | | | | Joined: Dec 2010 Posts: 9 New Guy | | New Guy Joined: Dec 2010 Posts: 9 | Thanks, will do. Not likely get done till after christmas. Thanks again. | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | you need to drive it more Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Dec 2010 Posts: 44 New Guy | | New Guy Joined: Dec 2010 Posts: 44 | Welcome Terry, hope you get your gauge problem sorted out. Keep us posted on your progress. | | |
