1 members (Gray_Ghost), 79 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
#702942 12/13/2010 12:58 AM
I have a 1966 C10 with a 250 and the carb is running very rich and I am not very good a putting in kits. Does anyone have a good carb or and advice for me.
climberman #702981 12/13/2010 3:09 AM
If it definitely needs a kit, I would take it to a local carb rebuilder. That would most likely be your best bet.
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
I would suggest you rebuild it yourself. It's really easy. I did mine and was surprised to see how easy it really was. Just take one section apart at a time and replace parts as you go. I NEVER have done anything with carbs but did it. Runs like a dream now. And saved a bunch of money. Kit is only like 17$
RustyStepper #703912 12/16/2010 3:10 PM
does Edelbrock have kits for my carb?? If so where do you get them? Local speed shop?
gazim #703920 12/16/2010 3:24 PM
I had already gotten someone to rebuild it and it was a little pricey. I have rebuilt them myself and they never run good so it was ether buy one or have it rebuilt. I still haven't put it on yet but will today.
climberman #704017 12/16/2010 11:10 PM
I have a 66 as well with the 250. I am going to rebuild my carb but I have also checked and Autozone carries the single barrel rochester carbs starting at $149.00.
Richard Morgan
1966 Chevy C10 LWB Stepside
More pix on Photobucket
Grandads_66 #704023 12/16/2010 11:34 PM
I paid 169 for the rebuilding so I should have call Autozone that sounds like the way to go.
climberman #704032 12/17/2010 12:15 AM
Riding in the Passing Lane
Wrong! It's better to rebuid the one that came with it. More then half the "remans" are not right. They juggle parts & have one part number fit many. They often don't match the engine.
1972 Chevy c10 Cheyenne Super
Don't forget to check your vacuum advance on the distributor. That is an easy,inexpensive fix that can really help with how the truck runs. If your timing in not advancing this could be contributing to the running rich problem.
Richard Morgan
Thats good to know Wrenchbender and that is way I come on here.
