6 members (walterhvogel, klhansen, Jman, Tom McGrath, UtahYork, Materman), 88 guests, and 2 robots.
Topics128,035
Posts1,055,557
#70384 12/21/2006 4:17 AM
Apprentice
Apprentice
Hi Guys
I tried searching for instructions on how to mount a remote oil filter in my car and how to connect it to my engine. But i have had no luck.
I have a 216 in my chevy styleline
my two questions are
1. is there a specific place to mount the filter or can i mount it wherever i want.
2. where do i hook up the lines for it.
Thanks and happy holidays
Chaimv
#70385 12/21/2006 4:22 PM
Ex Hall Monitor
Ex Hall Monitor
I believe your 51 would mount on the intake manifold if you have the beehive type filter. The intake hose would mount to a "T" at the pressure sending unit connection. The return hose would mount to the oil distributor valve. I'm sure someone will post a link to a pic. I put a modern spin on filter on my 38.
#70386 12/22/2006 2:43 AM
The return line goes to a fitting that drains directly back into the pan. This is the "bypass" filter setup and part of the oil flow is diverted through the filter and then into the pan.
1951 1 Ton Completed
#70387 12/22/2006 4:43 AM
#70388 12/25/2006 11:07 PM
Apprentice
Apprentice
Thanks for the diagram
I tried looking to see if i can mount it like that to my engine unfortunatley i cannot. the heat riser in my ar has the little hose that goes to the wipers so i cannot mount it on that side and there does not seem to be another suitable place for it
Chaimv :confused:
