3 members (homer52, Bill Hanlon, 1 invisible),
140
Mod | | | Forums66 Topics128,026 Posts1,055,408 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#70384 12/21/2006 4:17 AM | Joined: Sep 2006 Posts: 43 Apprentice | | Apprentice Joined: Sep 2006 Posts: 43 | Hi Guys
I tried searching for instructions on how to mount a remote oil filter in my car and how to connect it to my engine. But i have had no luck.
I have a 216 in my chevy styleline
my two questions are 1. is there a specific place to mount the filter or can i mount it wherever i want. 2. where do i hook up the lines for it.
Thanks and happy holidays
Chaimv | | |
#70385 12/21/2006 4:22 PM | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I believe your 51 would mount on the intake manifold if you have the beehive type filter. The intake hose would mount to a "T" at the pressure sending unit connection. The return hose would mount to the oil distributor valve. I'm sure someone will post a link to a pic. I put a modern spin on filter on my 38.
#70386 12/22/2006 2:43 AM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | The return line goes to a fitting that drains directly back into the pan. This is the "bypass" filter setup and part of the oil flow is diverted through the filter and then into the pan. | | |
#70387 12/22/2006 4:43 AM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | |
#70388 12/25/2006 11:07 PM | Joined: Sep 2006 Posts: 43 Apprentice | | Apprentice Joined: Sep 2006 Posts: 43 | Thanks for the diagram
I tried looking to see if i can mount it like that to my engine unfortunatley i cannot. the heat riser in my ar has the little hose that goes to the wipers so i cannot mount it on that side and there does not seem to be another suitable place for it
Chaimv :confused: | | |
