1 members (Materman), 107 guests, and 3 robots.
Topics128,072
Posts1,055,906
Members48,429
#70360 12/20/2006 4:06 PM
Is it necessary to have a spring compression tool in order to remove and replace the front coil springs on a 66?
I hear some coil springs can be quite dangerous to remove without the proper tools.
no, just take care. I used a clamp when it was up on jacks, other have used a long piece of all-thread.
the easyist I found was to jack it up, put on jack stands and use a bottle jack under the A arm.
when you get it loose, just let the bottle jack down slowly. I put them on that way too.
Riding in the Passing Lane
It,s the car springs that need a compressor. They are long & just keep growing. The truck springs are short & stout. They all need to be careful around. If you let the a arm down slowly you can lift it right out.
1972 Chevy c10 Cheyenne Super
Thanks guys
Just for safety I sometimes chain them with a short piece of chain and a bolt, if they fly they can't go too far. But usually they'll just go limp if you're careful
My other truck is a Ducati
