2 members (VicZ, klhansen),
118
Mod | | | Forums66 Topics128,072 Posts1,055,904 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#70360 12/20/2006 4:06 PM | Joined: Feb 2004 Posts: 336 Shop Shark | | Shop Shark Joined: Feb 2004 Posts: 336 | Is it necessary to have a spring compression tool in order to remove and replace the front coil springs on a 66? I hear some coil springs can be quite dangerous to remove without the proper tools. | | |
#70361 12/20/2006 4:27 PM | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | no, just take care. I used a clamp when it was up on jacks, other have used a long piece of all-thread. the easyist I found was to jack it up, put on jack stands and use a bottle jack under the A arm. when you get it loose, just let the bottle jack down slowly. I put them on that way too. | | |
#70362 12/20/2006 8:45 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | It,s the car springs that need a compressor. They are long & just keep growing. The truck springs are short & stout. They all need to be careful around. If you let the a arm down slowly you can lift it right out. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#70363 12/20/2006 9:41 PM | Joined: Feb 2004 Posts: 336 Shop Shark | | Shop Shark Joined: Feb 2004 Posts: 336 | | | |
#70364 01/10/2007 12:36 AM | Joined: Dec 2006 Posts: 19 New Guy | | New Guy Joined: Dec 2006 Posts: 19 | Just for safety I sometimes chain them with a short piece of chain and a bolt, if they fly they can't go too far. But usually they'll just go limp if you're careful
My other truck is a Ducati
