| | | Forums66 Topics128,072 Posts1,055,903 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#70324 12/19/2006 2:13 PM | Joined: May 2005 Posts: 4 Junior Member | | Junior Member Joined: May 2005 Posts: 4 | Hey brothertruckers, I have a 49/1ton flat bed. I want to convert it from one exhust to dual, so I can put stacks on it. What am I looking at, easy-hard. Any tips would be super. Tayninh | | |
#70325 12/19/2006 10:09 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You can have the original manifold split or get a set of headers. Have a muffler shop build the systems. Sounds like a cool idea. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#70326 12/20/2006 12:29 AM | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Or you can even use a 1-IN/2-OUT muffler, a poor mans way of doing it. | | |
#70327 12/20/2006 1:10 AM | Joined: Feb 2005 Posts: 469 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 469 | Unless you just want the twins a single 2 1/2'" with out a muffler sounds pretty good at about 3 grand and a hard pull. | | |
#70328 12/20/2006 3:05 AM | Joined: Mar 2005 Posts: 684 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 684 | I had stacks on a '52 one time they sounded great but the only drawback was the sooty condesation they blew out on start up in the morning. Have them curved on the ends to the sides of the truck and you might be OK | | |
#70329 12/20/2006 3:22 PM | Joined: May 2006 Posts: 237 Shop Shark | | Shop Shark Joined: May 2006 Posts: 237 | So what engine do you have? A new V8 is easy to make duals. An old 235 or 216 and you'll have to get a new / altered manifold or split the exhaust somewhere past the manifold.
Do you plan on running a muffler before the stacks? Wonder how noisy it would be with no muffler and stacks running straight up.
What size pipe are you going to run? A 3" pipe, dual stacks, on a 216... is NOT going to help your performance. A single 2" might, or a single 2.5" on a 235/261. A high reving 292 might like a 3", but that's pushing it.
A pipe (of the correct ID) needs to be long enough to allow exhuast gas momentum to help "pull" the gasses out of the chamber, but not so long that it restricts the air flow out of the chamber. It's a fine line, and I don't know of any certain way to determine it.
Old tractor pullers say to put a long straight pipe on, then run a crayon mark the entire length of the pipe. Run the engine till it gets completely warmed up. The location where the crayon mark has stopped melting is where the pipe should be cut. Sounds like voo doo to me, but maybe it works. | | |
#70330 12/20/2006 3:55 PM | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | Jhaa_lives,the crayon trick does work.Tayninh,I made duals on my 53 wrecker by mounting a piece of 4"X4" steel box tube between the frame rails and behind the cab.I welded the ends closed and brought two, 2" stainless stacks up from there with flanges welded to the top of the 4X4 box.Another flange was welded on the bottom for an inlet.With no muffler and rain caps it sounds great especially on a heavy long pull.
Wanted Good Woman: Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
#70331 12/21/2006 4:26 PM | Joined: May 2005 Posts: 4 Junior Member | | Junior Member Joined: May 2005 Posts: 4 | Thanks guys for you thoughts. Still thinking. My nephew told me about going to a muffler place. So all I have to do is find a how to split the exhust manifold? | | |
