8 members (Southerntruck, Gray_Ghost, Bill Hanlon, Otto Skorzeny, JW51, MRMEROTH11, Mike Burns, KEVINSKI),
77
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,133 Posts1,056,396 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 173 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 173 | My 450 gmc coe with the 302 squeals the belt at high rpm. I've tightend "the wizz" out of the belt, but upon looking at it closer I think that the belt is not the right width. It runs down in the bottom of the pulley grooves. All that is on the belt is a NAPA number(25-11000), but I think that it is a "A" belt or about 1/2" width. I would guess it needs a "B" width belt, but don't know. Does anyone know which width belt is correct and perhaps what length. I've got to pull the alternator again so now is a good time to make the switch. BTW all the belt pulls is the alternator and the fan. Thanks all. Scott
1947, 1950, & 1952 Chevrolet 1/2 ton 1952 GMC 450 series Cab Over Engine 1946 Chevrolet 2 Ton
| | | | | Joined: Apr 2010 Posts: 474 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 474 | If the belt is the correct size try belt dressing it works great!
| | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | A 302 uses either a 5/8 or a 7/8 belt. If your belt is too narrow, it will slip down into the bottom of the pulley and you never will get it to quit squealing. V belts were made to run on the V. If it has an alternator, it's not original and you may have a narrower pulley on the alternator than the fan and the crank. I would try a 7/8". I think the length is about 46". | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Scott's50, the o.e.m. p/n is 2190637 which crosses to Dayco 30445, that is a wide belt which is 44.5" long, hope that helps. | | | | | Joined: Nov 2006 Posts: 173 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 173 | Thanks everyone, I was sure a wider belt was in order and ya'll confirmed that for me. I'll pick one up today and that should cure the problem. BTW I swapped the alternator in when the generator quit, now the alternator isn't alternating, we've really progressed haven't we? The generator lasted 50+ years the alternator about 50 minutes, oh well.
Thanks again, Scott
