3 members (texas46, Otto Skorzeny, 55shaker), 178 guests, and 0 robots.
Topics128,100
Posts1,056,178
Members48,436
#702923 12/12/2010 11:14 PM
My 450 gmc coe with the 302 squeals the belt at high rpm. I've tightend "the wizz" out of the belt, but upon looking at it closer I think that the belt is not the right width. It runs down in the bottom of the pulley grooves. All that is on the belt is a NAPA number(25-11000), but I think that it is a "A" belt or about 1/2" width. I would guess it needs a "B" width belt, but don't know. Does anyone know which width belt is correct and perhaps what length. I've got to pull the alternator again so now is a good time to make the switch. BTW all the belt pulls is the alternator and the fan. Thanks all.
Scott
1947, 1950, & 1952 Chevrolet 1/2 ton
1952 GMC 450 series Cab Over Engine
1946 Chevrolet 2 Ton
If the belt is the correct size try belt dressing it works great!
Stovebolt Gallery
1952 Chevy 3100
1953 Chevy 4400
1965 Nova
Pics on Photobucket
A 302 uses either a 5/8 or a 7/8 belt. If your belt is too narrow, it will slip down into the bottom of the pulley and you never will get it to quit squealing. V belts were made to run on the V. If it has an alternator, it's not original and you may have a narrower pulley on the alternator than the fan and the crank. I would try a 7/8". I think the length is about 46".
3B Offline
Hy Scott's50, the o.e.m. p/n is 2190637 which crosses to Dayco 30445, that is a wide belt which is 44.5" long, hope that helps.
3B #703056 12/13/2010 1:15 PM
Thanks everyone, I was sure a wider belt was in order and ya'll confirmed that for me. I'll pick one up today and that should cure the problem. BTW I swapped the alternator in when the generator quit, now the alternator isn't alternating, we've really progressed haven't we? The generator lasted 50+ years the alternator about 50 minutes, oh well.
Thanks again,
Scott
