4 members (TUTS 59, PAUL Berardi, wilbur53, 1 invisible), 112 guests, and 0 robots.
Topics128,132
Posts1,056,376
Members48,441
#70283 12/18/2006 11:27 PM
Junior Member
Junior Member
Hi,
I am new and considering a 62 C10 and I think I would want a 5 speed. Has anyone done this in this year range? I have read the posts about the swaps in the older trucks and I was hoping that on the 60's vintage trucks it might be a little more straight forward. Thanks! Paul.
#70284 12/19/2006 2:26 AM
Z
Z Offline
if its a 235 go up to the search and type in 235 t5 also try www.chevytalk.com .i think the t5 will bolt to your bellhousing if you drill out two holes.
#70285 12/19/2006 10:16 PM
Riding in the Passing Lane
It,s pretty much the same swap in all of them. You have an open drive shaft so you will not have to change rear ends. I like to get a universal crossmember & put it under the trans. Some just let it hang out like the original but that long aluminum case is not meant for that.
1972 Chevy c10 Cheyenne Super
#70286 12/20/2006 1:27 AM
I would venture to say that there have probably been hundreds of T-5's put into 60-66 trucks. Almost any old truck site you look at has info on this swap...this particular site being by far the best of course. I have one in a '63 and love it.
Daily Driver 63 C-10 LWB Fleetside
