7 members (2-Ton, Shaffer's1950, Otto Skorzeny, Gdads51, stoveboltgator, klhansen, Rusty Rod), 91 guests, and 1 robot.
Topics128,048
Posts1,055,539
Members48,424
#70276 12/18/2006 10:05 PM
I did a search to help with this question but cant find the answer. I have a 57 3100 with a rebuilt 235 and Rochester carb. My manual says that idle should be 475rpm. I have is set at about 650 and it seems about right. 475 is really too low. I need your opinions. What do you set your idle speed at?
#70277 12/18/2006 10:11 PM
Kevs57,
I was always taught 500 RPM was the target idle speed.
Stuart
#70278 12/18/2006 11:18 PM
Riding in the Passing Lane
The specs are just a guide. Use what is comfortable.
1972 Chevy c10 Cheyenne Super
#70279 12/19/2006 2:50 AM
mine is at about 700, I like it that way..
Redryder pix
My Hotrod
#70280 12/19/2006 2:55 AM
usually between 550-600 is abt. right. its kinda just personal preference.
#70281 12/19/2006 3:11 AM
Mine is at about 300, but I generally use the hand throttle to increase it to generating RPM and for better cooling. It does pull OK from 300. This is on a 206.8 CID engine.
#70282 12/19/2006 5:49 PM
OK. Thanks to all of you for the response. When the weather warms up I will look at this again ( along with a brake job). It is running good so I may leave well enough alone.
