2 members (Peggy M, panic),
89
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#70276 12/18/2006 10:05 PM | Joined: Mar 2005 Posts: 58 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 58 | I did a search to help with this question but cant find the answer. I have a 57 3100 with a rebuilt 235 and Rochester carb. My manual says that idle should be 475rpm. I have is set at about 650 and it seems about right. 475 is really too low. I need your opinions. What do you set your idle speed at? | | |
#70277 12/18/2006 10:11 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Kevs57,
I was always taught 500 RPM was the target idle speed.
Stuart | | |
#70278 12/18/2006 11:18 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The specs are just a guide. Use what is comfortable. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#70279 12/19/2006 2:50 AM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | mine is at about 700, I like it that way.. Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
#70280 12/19/2006 2:55 AM | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | usually between 550-600 is abt. right. its kinda just personal preference. | | |
#70281 12/19/2006 3:11 AM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | Mine is at about 300, but I generally use the hand throttle to increase it to generating RPM and for better cooling. It does pull OK from 300. This is on a 206.8 CID engine. | | |
#70282 12/19/2006 5:49 PM | Joined: Mar 2005 Posts: 58 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 58 | OK. Thanks to all of you for the response. When the weather warms up I will look at this again ( along with a brake job). It is running good so I may leave well enough alone. | | |
