3 members (Hotrod Lincoln, TooMany2count, 1 invisible), 120 guests, and 6 robots.
Topics128,021
Posts1,055,354
Members48,420
#702521 12/11/2010 6:08 AM
#702550 12/11/2010 1:42 PM
What rad did you use ? looks a good fit.
layback
laybacklenny #702619 12/11/2010 5:23 PM
Leo Offline
Moderator
Moderator
Everything about that looks good. I better get busy...
Leo #702635 12/11/2010 6:54 PM
Got the rad at a swap meet was told it was right size and it was.Just spend two days on mounting brackets.
thanks 1953 panel been on it 7 years but i only work about 40 to 50 days a year on it.
jos48chevy #702724 12/12/2010 2:15 AM
Thats a lot of work on the panel. I can surely appreciate all the work you have put into it. I like the way you did the gas/brake pedal and I notice you slide an independent frontend under it. Sometimes I wish I had took that route. For the time you work on it your doing a fine job. Good luck on the rest of it.
Achipmunk #702772 12/12/2010 6:14 AM
That's quite a transformation. You've done a ton of work.
And people say mine was a pile.
1951 Chevy 1-Ton Panel
Pictures of the restoration on Photobucket
RIP good friend.
jos48chevy #1052825 08/30/2014 1:54 PM
At last paint on the panel
jos48chevy #1052944 08/31/2014 1:23 AM
Jos48, been wondering what happen to you. Good job and thanks for posting. panel is looking good.
It'd be nice to see you at the Stovebolt Reunion next week.
