1 members (2-Ton),
141
Mod | | | Forums66 Topics128,162 Posts1,056,941 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 161 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 161 | anyone know where I can get distributor springs? and a shaft pin? | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | I have had some luck searching ebay using Delco Remy NOS for the search query the small stuff is usually reasonable. | | | | | Joined: Nov 2009 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2009 Posts: 35 | Is it a 6 or a V8?
Stock Chevy 6 cylinder distributors I have rebuilt use a 3/16 x 3/4 pin. V8's use 3/16 x 7/8. However a number of the 6 cylinder distributors have had the hole in the shaft rounded out. The gear seems to be fine due to the hardness. This can be repaired if the hole is not too oblong by drilling both together on a drill press to 7/32 and using the correct size pin. You can get a pin from an industrial supply store. They will have the specs for the actual pin min/max hole size. Specify a hardened carbon steel roll pin. Avoid stainless or low carbon pins due to shear strength. | | |
