0 members (),
164
Mod | | | Forums66 Topics128,149 Posts1,056,818 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2010 Posts: 202 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 202 | Not too much further down this list is good advise on rust removal, but are there good, safe methods for removing corrosion from aluminum items like Carb and fuel pumps?
Walt Williams La Verkin, Ut | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | I tried using a commercial product normally used to clean aluminum window frames. Bad move. Totally spotted the finish on a carb.
Drew
| | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | Sandblast ??...I have done a bunch of intakes and carbs ...now I tape of the internal passages and just do the outside. A good wash afterwards removes the leftover grit. And you have a as NEW CAST part. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | It would be nice to hear from a pro on this one. Isn't a chemical dip a common method of cleaning carburetor parts? Instead of using silica/sand blast, wouldn't soda blast, walnut shell blast, and as a last resort, plastic media blast be better (if available)?
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | if aluminum is really oxidized, mechanical polishing is the only thing that'll clean it .... aren't carbs originally anodized or coated with some zinc compound? carb cleaner is available at the FLAPS, or failing that Brake Kleen ... I believe Eastman has kits for carb refinishing, including paint that gives a "factory" look finish
Bill | | |
