5 members (Otto Skorzeny, klhansen, Wally / Montana, DadsFirstPickup, Tiny), 188 guests, and 4 robots.
Topics128,077
Posts1,056,017
Members48,433
Junior Member
Junior Member
Engine rebuild gurus,
Are there any tricks to installing concave freeze plugs in 235/261 engine blocks. The plug I need to install is located behind the bell housing, so a leak would be very unhandy if discovered after the engine is installed. I looked in the GM factory manual and did not see this topic addressed.
Thanks for the help, Bill.
Bill in Colorado
Are they the kind that look like a bowl?I use a big socket to install them, also i put a bit of sealer on them.The other type is curved out, they sit on a lip in the casting, you put some sealer on them and punch the center to expand them. i use a big punch thats smooth so i dont ding em up much.Hope this helps...Tom
I think the one behind the bell housing is the convex type that sits on a lip. If so, put some sealant on it and hit the centre to expand it. A rebuilder told me to place a hammer on the centre and then strike the hammer with another hammer. I have some photos in my webshots of mine before and after.
http://rides.webshots.com/photo/1316417356041873203xTDshC
I replaced mine when I had the toeboard cut out.
1951 1 Ton Completed
