4 members (ShopRag, Youngin' Tut 59, jay d, 1 invisible), 124 guests, and 2 robots.
Topics128,139
Posts1,056,756
Members48,454
Could someone help with the specifics on where to mount antenna? Cowl on passenger side? Could someone help with details, specifics,etc.Thanks,
k10 Offline
Same as a pickup. Passenger side cowl panel. The little one behind the hood. The Assembly Manual shows the precise location. Sometimes you can find a cowl in the junkyard which will show you the location, or if it's good enough you can just use it.
can measure mine if you need it, drop me an email
Not sure if i have that manuel, though thanks for the reply. Take Care
