1 members (2-Ton),
141
Mod | | | Forums66 Topics128,162 Posts1,056,941 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 21 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2007 Posts: 21 | Could someone help with the specifics on where to mount antenna? Cowl on passenger side? Could someone help with details, specifics,etc.Thanks, Kevin | | | | | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | Same as a pickup. Passenger side cowl panel. The little one behind the hood. The Assembly Manual shows the precise location. Sometimes you can find a cowl in the junkyard which will show you the location, or if it's good enough you can just use it. | | | | | Joined: Sep 2006 Posts: 335 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 335 | can measure mine if you need it, drop me an email | | | | | Joined: Oct 2007 Posts: 21 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2007 Posts: 21 | Not sure if i have that manuel, though thanks for the reply. Take Care | | |
