1 members (baldeagle),
55
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2010 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 43 | I have 2 separate dash clusters that I need to test the gauges on. One cluster has the actual gauges for temp, battery, oil and gas and the other has the fuel and idiot lights only. I have tried to find (via the web) if there is an easy way to test these off the vehicle w/o blowing them up. I realize that the oil gauge will have to have actual pressure on it, but will all the rest test with the same procedure...whatever that is? I hope I don't sound like an idiot myself here, but I am new to his "hobby". Thanks! Janine | | | | | Joined: Aug 2009 Posts: 295 Shop Shark | | Shop Shark Joined: Aug 2009 Posts: 295 | Janine
The oil gage is simplest - you can test with compressed air. Use regulator and start at zero and crank regulator up. Have separate gage to compare to they should agree +/- 5psi or so.
Power for testing can be supplied with small batteries.
Have switch so you can turn on and off quick. Close sitch and see if goes right way - if not open switch. One or two second wrong should not hurt.
Temperature would be best done with sensor in cup of hot water with thermometer. Watch out for polarity.
Ammeter check meter to determine if it is to be connected in the line or if it is a 50 mV unit requiring shunt. You will need a load. Go to Radio shack and get a 5 and one ohm resistor. Connect resistor in series with meter - if line type. If shunt connect shunt inseries and connect the Output leads to meter.
Dan Bentler | | | | | Joined: Jul 2010 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 43 | Thanks Dan!I took a small battery and a cooupl eof test leads just touched them to the gas gauage and saw it move. Now, if it ever warms up enough, I'll go check the oil pressure gauge. (Living in MI is Hell in the winter for this. I need a heated garage!) Janine | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | JD dont try to [censored] me. It is 27 at my house today and I bet at yours. | | | | | Joined: Jul 2010 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 43 | Gary, You'd think I'd be use to this by now. But seems the older I get the less I like it. Maybe that's why all the old people in Florida are actually MI people? ;-) | | |
