4 members (baldeagle, NorCal52Suburban, DaveV, Opelika Tom), 107 guests, and 1 robot.
Topics128,037
Posts1,055,470
Members48,424
#700895 12/04/2010 11:21 PM
Will a 1954 235 Chevy Truck engine bolt up in a 1947 Thriftmaster Chevy Truck which has a 216? I have a friend who has a newly rebuilt 235 I can get very reasonable. Thanks!
Scottie #700933 12/05/2010 1:22 AM
Yes, it will bolt right in.
Scottie #700936 12/05/2010 1:26 AM
The 1954 will have the exhaust exit the manifold at an angle back, the 47 exits straight down.
The front timing plate will most likely need to be drilled for the front mounts.
Easy swap.
My Blog
Cletis #700939 12/05/2010 1:36 AM
The bellhousing mounts will be different(on the rear crossmember),but the bellhousings will interchange w/eachother.
Other than that,maybe the gas pedal linkage might be a little different,longer or shorter.
Youll be doing a swap thats been done thousands of times,with just very small differences in the 2 motors.
The 54 235 truck engine's front timing plate should not need to be drilled for the front mount, as the 54's used a front engine mount.
Samantha
1954 Chevy 3100
Picked from the Field
Follow in the DITY
Samantha #700994 12/05/2010 5:17 AM
details, details, details . . .
. . . in the end, we (as a group) seem to almost always get it right
chug
tclederman #701015 12/05/2010 7:32 AM
Direct bolt in,use the bell housing off your 216.The throttle linkage may need a little attention,GO FOR IT !!!!!!!!
Tim
1951 3100 Chevrolet
