3 members (Materman, blanch53, 1 invisible), 125 guests, and 2 robots.
Topics128,072
Posts1,055,906
Members48,429
#700676 12/04/2010 3:56 AM
1 Offline
Does anyone know where I can get a lower radiator hose for my 1953 3100. It has a 235 six. I ordered a hose from Brothers Trucks and it fit the radiator but not the water pump. My water pump requires a larger diameter hose on that end. I tried the local auto parts stores with no success. Appreciate any help on this.
1953 3100 Chevy 5 window
1971 Chevelle SS
Y
yar Offline
Y Offline
'53 Chevy I've had success asking to look at racks of radiator hoses in parts stores. You'll find one that will work.
Ray
If I understand this correctly, you have a 55 or later water pump and a 54 or earlier radiator. So, you need a hose with different inner-diameters at each end?
I bought a hose as suggested by Ray, that has the wider/larger diameter (mine had a corrugated outer-body that allowed bending to fit the needed angles). I had a good lower hose with the smaller diameter. I cut the last inch off the smaller hose and was able to put that piece inside the radiator-end of the larger diameter hose. No leaks and a good fit.
I used to use this book all the time at the parts store to find hoses for odd ball applications. Hard to tell fine details, but gets you a list of numbers to try:
http://www.chuckthetruck.com/files/ProductGuideHose.pdf
It is big - 7.5MB - but worth the wait.
Good luck!
That's cool Chuck, but who's part numbers are those???? I'd bet if I walked into the AutoZone store with an unknown brand part number I just get a blank stare.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Measure your nipple diameter on the radiator and the nipple diameter on the water pump.The local auto parts store will have it in a flex hose.I had the same problem when I put my 54 261 in my 51 Chevy truck.
I believe I went with a 20" long gates #25530 flex hose.
flex hose 25530
I tried the gates #20230 and took it back,must not have fit.
Tim
1951 3100 Chevrolet
1 Offline
Thanks guys, I like Tim's idea of using a one inch smaller hose inside a larger one. I found several that matched the water pump but was a little to large for the radiator. Using the smaller hose should work. Fyi, my 235ci is from a 62 and I'm sure I bought a water pump close to that year.
I'll also check on the flex hose as well. Thanks for the help. I can always depend on you guys when I get stuck.
1971 Chevelle SS
Denny,
I think Tim got it right.
Gates Rubber Company (Canada), looks to be the part numbers that Chuck has provided.
If you get a blank stare at Auto Zone you better go to another FLAPS.
To do a parts number search/interchange, you do not need the company name, just the part number.
25530 at CarQuest is the same part # 25530
-Tom
1950 Chevy 3100 w/ 1956 235
Jim Carter has a lower hose designed for the original radiator and later 235 water pump. I ordered one and it works fine but seems a little flimsy (thin walled), so I don't know how long it will last.
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
I did my cob-job fix in 1971. If correct hoses are available now, I'd use it (but, I do not need it now because I am using the older water pump, with the water-pump relocation plate).
Yup - Gates numbers. You can the book at their website, but have to fill out a form.
Just got back from NAPA and went in back to check the rack for radiator hoses and found one hose that worked for upper and lower.I have a 1946 GMC one ton with a`54-55 261 with high waterpump the hose number is 9050.It has a 1-1/2"size on one end and 1-3/4" on other end.I cut to fit the lower hose and the remaining piece fit the upper perfect after triming about 3" off lenth
I ordered one from Jim Carter - very happy with it. Don
