2 members (Otto Skorzeny, Gray_Ghost), 131 guests, and 1 robot.
Topics128,080
Posts1,056,063
Members48,433
Finally I recieved my bearings. Someone pointed that front wheel bearings as well as differential needs a preload. How do you determine when do you rech the proper load? In the front I guess it might be easier using a torque wrench, but on the differential whih should be the procedure?
ODSS Lawman
ODSS Lawman
A torque wrench is perfect for setting preload on the front bearings. Check out a shop manual HERE you will see the proper torque is 33 foot pounds.
As for the second part of your question, what exactly do you mean by preload in the differential? Are you referring to carrier bearing pre-load, or something else?
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
I'm sorry, cheching the shop manual the adjusting nuts are for adjusting contact between pinion and gear, thought it was for preloading the carrier bearings, those are tappered roller bearings, so no need for preload.
Thanks for pointing it out
