| | | Forums66 Topics128,159 Posts1,057,033 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 239 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 239 | I've got a '55 1st series. There is no interior rear view mirror. Want to buy and install an interior rear view mirror. Where is the original location for the rear view mirror? | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | In the center just above the window gasket. Screws to the header. use a short drill and short screws so you don't pop thru the roof, it's close to the header. DG
Denny G Sandwich, IL
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Might be a bit late for you Nels, but this might be of some interest to someone else: http://www.pbase.com/dennygraham/image/130871288/large It shows a cross section of the bracket mounting to the header. Denny Graham Sandwich, IL
| | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Tim - I searched your site and the Old Car Manual Project site for the complete "1954 Chevrolet Accessories Installation Manual." Is it available on-line? Thanks, - Lonnie
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Apr 2008 Posts: 239 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 239 | The diagram is great. I was not sure if the rear mirror was even supposed to be in the truck. There are no holes for the mirror. I'll order the mirror and now I know where and how to install it. I am surprised that the truck did not have the holes already drilled for the mirror. Thanks for all your help. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Lonnie,
I do not think that the 1954 Chevrolet Accessories Installation Manual is on-line.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Hey Tim, did you look at the link I posted yesterday??? I out fumbled you by a couple of hours. I don't think it is either, I had to order one from one of the vendors. Can't get everything for free guys.
Denny G
| | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Denny, Tim, & nels1954 -
A follow up ... I installed the inside rear view mirror that I've had for 10 years. And I bought a 1954 accessories manual. This mirror gave a tremendous boost to my driving pleasure and safety.
- Lonnie
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Jun 2007 Posts: 39 'Bolter | | 'Bolter Joined: Jun 2007 Posts: 39 | I do not know what the windshield upper rail is. so am I supposed to place the mirror I/2 inch above the window rubber gasket and then drill the pilot holes (which would probably be about an inch from the edge of the window gasket? this is probably a stupid question, but I am not a mechanic. thanks for your help jim | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | I do not know what the windshield upper rail is. so am I supposed to place the mirror I/2 inch above the window rubber gasket and then drill the pilot holes (which would probably be about an inch from the edge of the window gasket? this is probably a stupid question, but I am not a mechanic. thanks for your help jim ...pic... I'll give you a bump
| | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | gmman4
The upper rail is part of the sheet metal for the windsheld / roof. It is pictured in the posts by Denny Graham, Tim Lederman, and the bump by DADS50.
When I installed the inside rear view mirror in my '54, I couldn't remove my cardboard headliner without some major work, which would make locating the place to drill the holes easy. I musta measured and figited for a couple of hours. I finally took a SWAG and drilled through the cardboard headliner. Luckily, I hit the rail - but just barely.
If you can slip something undern the headliner to feel the location of the rail, or even better if you can move or remove the headliner, then do so. The cardboard is so thick that it is almost impossible to feel the location of the upper rail through it.
One more thing ... I suggest that you make a depth stop for your drill bit so that you do not dimple the roof when you punch through the upper rail. The rail is fairly heavy gauge steel and takes some effort to drill through.
Hopefully someone else will give you better info.
- Lonnie
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Jan 2011 Posts: 159 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 159 | Did not see the earlier thread. Here was my post on the same topic. I hope I am on target.
"Just want to sure I understand with drill in hand. Looks like the safest way is to place the bracket against (or very close to) to the rubber trim. From the diagrams, I see no danger in that. I really don't get the 1/2" measurements in the Chevy diagram, which seems like overkill. What about just go right up to the rubber, mark, and drill? What say you?"
Thanks, Harry. | | |
