4 members (klhansen, HandyAndy, Otto Skorzeny, Hush), 81 guests, and 1 robot.
Topics128,092
Posts1,056,040
Members48,433
#699012 11/28/2010 7:50 PM
I am going to clean out and reseal my steering box, but I havn't found anyone that sells a rebuild kit for it. It's a 66 Burb, 292 manual steering, 2 wd. Does anyone know where a rebuild kit is available for these? I don't see it in the parts books, and I havn't found it at the FLAPS.
Thank you for your help
Drew
From what I see, this kit is for a 55 - 59 Box. I assume that the 66 is a different style Box, or am I incorrect on this assumption?
oops. My mistake. I did read that www.classicparts.com sells rebuilt steering box for $200 if you're interested.
Sorry about the mix up.
Drew
Just an update for you, I could not find any one that sells a kit, and the local FLAPS sell the Pitman arm seal. But, I did find that the Truck Shop in Orange CA, www.truckandcarshop.com does sell most of the seperate items, seals, bushings, bearings, etc. They have a pretty good selection on various items, and the pricing seems good. The one item of interest, is the gasket that goes under the side cover plate ( it's actually on the top of the gear box ). It is priced at 39.00, and I'm thinking it's got wire mesh reinforcing or something. Nope, it's basically just a plain old paper gasket, but it's GM NOS. So, if you need the parts, buy everything else, and make your own gasket.
Check out rockauto.com too. They had most of the steering parts for my 62 k20.
