0 members (), 116 guests, and 2 robots.
Topics128,105
Posts1,056,541
Members48,448
#700375 12/03/2010 1:27 AM
I have the chance to pick up a nice (54) 235 but I am not sure if it is out of a car or a truck? The PO says it came out of a 54 pickup at least that is what the guy he bought it from said. Can you tell by just looking at the motor what it came out of?
Post the number from the distributor pad and someone with a book will tell you.
Cletis are you refering to the number just to the left of the distibutor towards the back of the motor
yes.
Cletis #700613 12/04/2010 12:06 AM
I had a chance to get a number off the motor it is 040II85F54X is it a car or a truck motor???
mperk #700626 12/04/2010 12:49 AM
I'll give it a try,but I'm not sure what the I or 185 stands for.
040II85F54X
04=assembly month=April
01=Assembly day=1st
185=???
F=plant=Flint
54 year
x=type=Truck 235 manual Transmission
1954 codes
1951 3100 Chevrolet
Tim's got it right for the F54X
0401185 is the unit number (sequence number)
Look right above the 1954 engine information to see the the changed format in 1954. However, there is not 1954 truck information on that page.
This page has better information about the 1954 serial numbers.
Tim,your second link looks like same one I linked,I think.
Tim
1951 3100 Chevrolet
Tim,
You may want to check your first link listed as....
"Look right above the 1954 engine information"
It's coming up as...
http://wiki.answers.com/Q/How_many_US_senators_and_congressmen_are_convicted_felons
-Tom
1950 Chevy 3100 w/ 1956 235
Oilrag #700747 12/04/2010 10:40 AM
Thanks, Tom. I fixed it (I got distracted by a Greasy Spoon thread).
Tim,
That's right - dis you see the decoding of the number pre-fix in the engine serial number?
Both links in my post now show how to interpret the 7-digit sequence of numbers in 1954.
"Unit Numbers: start with 1001 at each plant."
Maybe I am reading this wrong? That is a high engine number for 1954, unless the engine unit/sequence number is for all engines (car and truck)?
