| | | Forums66 Topics128,034 Posts1,055,542 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2009 Posts: 37 New Guy | | New Guy Joined: Dec 2009 Posts: 37 | I have a 61 chevy. I live in Illinois, it doesnt get bitterly cold, but it does get cold enough to freeze. Lately when it rains my door freezes shut pretty tight. i can usually crack it open, but does anyone have suggestions for the 'C' shaped lock? water collects underneath it and freezes, making entry impossible | | | | | Joined: Dec 2009 Posts: 37 New Guy | | New Guy Joined: Dec 2009 Posts: 37 | I gave it a good coat of wd40, thats it | | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | You might have to take a hair dryer to it and get it good and dried out. If the moisture lingers in there, it will just refreeze again. | | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | an old truck pal of mine from New Hampshire has this suggestion:
What worked for us up north was to shoot a bunch of graphite into the lock itself (buy cheap at hardware store) and use lithium grease on the hinges, clasp and inside the door panel on the locking/door handle mechanisms.
Do NOT use WD40, PB Lube or hot water!!
No idea why, but the spray lubes always make it worse. | | | | | Joined: Apr 2006 Posts: 273 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 273 | Do NOT use WD40, PB Lube or hot water!!
No idea why, but the spray lubes always make it worse. WD-40 and other spray lubes attract dust, even in cold weather (static electricity?) and you end up with a gummy, mucky substance that jams everything up. I found that out by fooling around with locks and getting a good hearty laugh from my locksmith before he explained it to me. | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | You need to check for the source of the water and how it is getting in. You may have a bad seal or parking under an overhang.
The only problem I remember (growing up in Michigan) was after a freezing rain the lock openning would freeze over. I would simply take off a mitten and cover the lock with my hand. This always left a round red mark on my hand. LOL
Best of luck
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Nov 2010 Posts: 109 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2010 Posts: 109 | DW40 is a solvent, not a lube, so it cleans real well, but something like motor/bicycle chain spray on lube will stick on the surface. | | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | I've has problems with rubber door gasket freezing.Rubbing in di-electric grease helped | | | | | Joined: Dec 2009 Posts: 37 New Guy | | New Guy Joined: Dec 2009 Posts: 37 | alright, thanks for all the suggestions, i'll try graphite first | | |
