0 members (), 39 guests, and 4 robots.
Topics128,014
Posts1,055,327
Members48,419
#700342 12/02/2010 11:33 PM
Can anyone recommend a good source for a leaf spring spreader for my 42 3/4 ton? (loaded spring length is 36 inches)
I suppose I could just rent one for the job but, my son also needs to use one for his 62 Willys and, I understand they're not that expensive. Maybe someone has one they'd like to sell.
Any input will be appreciated. Thanks.
Ghost Rider
Little Egg Harbor, NJ
1942 Chevy 3/4 ton pickup, 1962 235, Offy intake, Fenton headers, Dual Carter YFs, 1984 T5
1956 Chevy 3100 Apache, 67 350SBC, Saginaw 4 speed, 69 12 bolt
What is it?
I don't remember needing anything special for the new leaf springs on my truck.
There has to be a reasonably safe way to do it without going out to buy or rent a tool, leaf springs are pretty simple.
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
Grigg #700512 12/03/2010 4:05 PM
spring spreader?? got a reference from the shop manual where a Ford tool is useful on a Chevy truck?
squeeze #700533 12/03/2010 5:28 PM
Spring spreader probably isn't the right term for it, as its normally used to pull a spring into an arc position to install it on some vehicles that have a preload on them.
Really doubt that you need to use one though, but in a pinch I've used a come-a-long to pull it together.
1946 Chevy 1/2-Ton
More pix on Photobucket
Sometimes I forget where I left myself....
andy46 #700590 12/03/2010 9:58 PM
Thanks to all for your input on my question. I've only done Model A leaf springs in the past so, I fell back on that experience. Apparently, Chevy leaf springs are not a problem to install in their unloaded state. Thanks again.
Ghost Rider
