8 members (Hotrod Lincoln, Gdads51, Bill Hanlon, JoeDude, frogfarmer, tclederman, gswbbc, dt235sd), 85 guests, and 2 robots.
Topics128,038
Posts1,055,536
Members48,425
#700369 12/03/2010 1:25 AM
I have a 61 chevy. I live in Illinois, it doesnt get bitterly cold, but it does get cold enough to freeze. Lately when it rains my door freezes shut pretty tight. i can usually crack it open, but does anyone have suggestions for the 'C' shaped lock? water collects underneath it and freezes, making entry impossible
Locomah #700373 12/03/2010 1:25 AM
I gave it a good coat of wd40, thats it
Locomah #700496 12/03/2010 3:18 PM
You might have to take a hair dryer to it and get it good and dried out. If the moisture lingers in there, it will just refreeze again.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
Rich'sToys #700522 12/03/2010 4:33 PM
Socket Breaker
Socket Breaker
an old truck pal of mine from New Hampshire has this suggestion:
What worked for us up north was to shoot a bunch of graphite into the lock itself (buy cheap at hardware store) and use lithium grease on the hinges, clasp and inside the door panel on the locking/door handle mechanisms.
Do NOT use WD40, PB Lube or hot water!!
No idea why, but the spray lubes always make it worse.
Woogeroo #700531 12/03/2010 5:15 PM
WD-40 and other spray lubes attract dust, even in cold weather (static electricity?) and you end up with a gummy, mucky substance that jams everything up.
I found that out by fooling around with locks and getting a good hearty laugh from my locksmith before he explained it to me.
You need to check for the source of the water and how it is getting in. You may have a bad seal or parking under an overhang.
The only problem I remember (growing up in Michigan) was after a freezing rain the lock openning would freeze over. I would simply take off a mitten and cover the lock with my hand. This always left a round red mark on my hand. LOL
Best of luck
Dennis
Woogeroo #700857 12/04/2010 9:13 PM
DW40 is a solvent, not a lube, so it cleans real well, but something like motor/bicycle chain spray on lube will stick on the surface.
Jon S
Las Vegas NV
1966 GMC Suburban 305V6
Psalm 66 "Make a joyful noise"
http://i12.photobucket.com/albums/a205/gvdobler/0205011645b.jpg
Jon_S #700892 12/04/2010 11:01 PM
I've has problems with rubber door gasket freezing.Rubbing in di-electric grease helped
BC52 #700922 12/05/2010 12:34 AM
alright, thanks for all the suggestions, i'll try graphite first
