4 members (Hawkman, MikeStone1953, 55shaker, Gdads51), 164 guests, and 2 robots.
Topics128,086
Posts1,056,099
Members48,434
#700115 12/02/2010 2:39 AM
I pulled my engine and replaced the rear main seal and all gaskets. I have it back in and it will only run with the choke closed. (at 1500 rpm or more) It has a Zenith which ran great before. I have the adjustable main jet out one turn and the idle jet out 1½ turn. If I crack the choke open even a hair it dies.
The only differences from before are a rebuilt distributor and Fenton exhaust with no pipes yet. I don't see how this would affect it. What am I overlooking?
0
0 Offline
I suggest that you check very carefully for a vacuum leak. The engine is getting too much air. You might have left a fitting off on the intake or broken the seal on a gasket. Joe
The intake manifold wasn't properly seated. It runs sweet now. Thanks for the suggestion.
