| | | Forums66 Topics128,037 Posts1,055,466 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#70025 12/14/2006 9:11 AM | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | A kid down the block is pulling the engine (a 216 that runs fine) out of a '47 Chevy car and wants to install it in his '49 Chevy 3100. He wants to use his truck 4 speed,but it won't hook up to the car bellhousing-the pattern on the bellhousing is a very small 4 bolt pattern. So he figured he'd just use the 3 speed from the car;but he says the car tranny is 3 or 4 inches too short. How much adjustment is available in the torque tube for different length? Seems like there should be provision for some movement forward & backward of the tube/axle. What options does he have? :confused: The truck had no engine so no truck bellhousing to change to. He kinda boxed himself in with other commitments and only has about 3 weeks to get the truck operable  (and it's pretty scattered right now!)so I told him I'd see what I could find out for him. Thanks! Speed | | |
#70026 12/15/2006 3:44 AM | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | If he uses his truck bellhousing... his truck 4 speed should bolt right up. The bellhousings are interchangeable on chevy and gmc inline engines from about 37-62. The bellhousings have slightly different configurations for mounting in a car or truck, or for different transmissions, but they all bolt to the engine in the same way.
John | | |
#70027 12/15/2006 12:17 PM | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | See,the problem is he doesn't have the truck bellhousing. He got the truck without engine or bellhousing,and wants to use the '47 car engine but it won't hook up to his truck 4 speed,and if he uses the 3 speed from the car,it's too short by about 8 inches. He told me today he's going to make an adapter plate from 1/2 inch aluminum to connect the truck tranny to the car bellhousing. He said he'd pull the pilot bushing out of the crank about an eighth of an inch for just a little more support. Also,he's going to heli-coil the bolt holes and use loc-tite to make sure things stay where he puts 'em. We'll just have to see how it turns out I guess. Speed | | |
#70028 12/17/2006 10:50 PM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Wouldn't it be easier to find a truck bellhousing? I have one he can have IF he'll take it off...
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
