| | | Forums66 Topics128,087 Posts1,056,112 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I pulled my engine and replaced the rear main seal and all gaskets. I have it back in and it will only run with the choke closed. (at 1500 rpm or more) It has a Zenith which ran great before. I have the adjustable main jet out one turn and the idle jet out 1½ turn. If I crack the choke open even a hair it dies.
The only differences from before are a rebuilt distributor and Fenton exhaust with no pipes yet. I don't see how this would affect it. What am I overlooking? | | | | | Joined: Mar 2007 Posts: 64 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2007 Posts: 64 | I suggest that you check very carefully for a vacuum leak. The engine is getting too much air. You might have left a fitting off on the intake or broken the seal on a gasket. Joe | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The intake manifold wasn't properly seated. It runs sweet now. Thanks for the suggestion. | | |
