0 members (),
64
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 368 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 368 | Members: I have a 49 4 speed tranny,( iN A 54 3100) How do I check the fluid level? I pulled the carpet,and tranny cover plate...I can't find the dip stick....nothing in the engine compartment... I just got the truck and I want to flush all fluids ( Kerosene or diesel ). I JUST CAN'T FIND WHERE TO POUR IT. PLEASE HELP A NOVICE. | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | There is a pipe plug about 1/2-way down the case (I think on the DS then there is a drain plug on the very bottom rear. Take the plug out on the side and feel around for oil in the case if you cannot feel it add (through the same hole)until it just starts to come out the hole. If it has not been changed in decades you may want to drain it followed by a kerosene wash (refill with Kerosene and run it back and forth in the driveway a few times). It takes something like 2-1/2 quarts I think to fill it (should be in the owners manual). Good luck. | | | | | Joined: Aug 2010 Posts: 368 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 368 | | | | | | Joined: Aug 2010 Posts: 368 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 368 | ok...I just cleaned the top of the tranny...got this number GM4 591688......On side B 149, # 4 GM 591665...So what do I have ? and where is the fluid check and filler?
confused. | | | | | Joined: Aug 2010 Posts: 368 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 368 | silly me...top # is 591568...bad eyes... | | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | Should be the SM420 4 speed with granny low used from about '48 to '67. A shop manual would be helpful to you. | | | | | Joined: Aug 2010 Posts: 368 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 368 | Thanks for the Info...I wanted to get alittle more specific than the general years...Also,I have the shop manual and Owners manual, I can'f find instructions on checking fluid level or changing/filling...but then again I'm cleaning with kerosene and alittle loopy. Thanks Again. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Drain plug on the bottom, and filler plug on the passenger side (about half way up the case). Fluid/lubricant goes into the u-joint housing from the transmission (if you still have the enclosed driveshaft).
| | | | | Joined: Aug 2010 Posts: 368 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 368 | Tim: I saw the drain plug...and noticed the passenger side plug... Now the passenger side is the fill side? I guess I need a flexible filler tube.... I have an enclosed driveshaft, Do I fill the U-Joint somewhere ? or does it get fluid when I put it in the right side hole? Also, I removed my speedo drive,cleaned it made sure it spun..is there a washer/gasket between it and the tranny housing,or is it metal to metal ( mine didn't have a gasket). And...can you decipher the tranny numbers to get a specific year,so I know when asked. It is a 4 speed with a granny and a side port for PTO.. Thanks for helping | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I will not attempt to identify the year of an SM420 transmission. Here is general information: http://www.novak-adapt.com/knowledge/sm420.htmDate code info here (after you narrow down the years from info in the link above): http://members.cox.net/cglabe1/SM420/sm420.htmlAs stated above: "Fluid/lubricant goes into the u-joint housing from the transmission (if you still have the enclosed driveshaft)." That is also described in the Owner's Manual and/or Shop Manual. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Filling through that hole can be done with one of the plastic fill bottles with the tapered neck. Usually gear oil comes in those containers. I use 85W90 in mine. | | | | | Joined: Feb 2006 Posts: 549 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 549 | I bought a pump that attaches to a gallon jug for transmission and rear end filling from the local parts store. They're only about 10 bucks and well worth it. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I have used the techniques described by truckernix & Avette4me.
This last time, I was lazy and took out the shifter rod and filled the transmission from the shifter-rod hole in the top.
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Well, I learned that you can suck the oil into one of those bottles if the occasion demands.
By the way, buried somewhere in the shop manual it talks about the fill level as being at the bottom of the hole when warm or 1/2" below when not warm. You may want to observe that. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Aug 2010 Posts: 368 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 368 | Again, Thanks for all the good info. How about the gasket between the speedo drive and the tranny housing? Is there one or metal to metal contact... Thanks | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I think there is no gasket in that location.
