4 members (Otto Skorzeny, Jon G, JacobU66, 1955 1 Series), 69 guests, and 1 robot.
Topics128,026
Posts1,055,399
Members48,422
#700010 12/01/2010 8:34 PM
If I want to run dual exhaust on my stock "54" 235 do I also have to change out the intake manifold or can I run dual Fenton exhaust manifolds by themselves. Will I have a problem with the heat riser?
mperk #700055 12/01/2010 11:42 PM
You will use the same intake manifold. There is a heat riser adaptor that you can buy that bolts to the bottom of the intake manifold and is connected via two tubes to each header. I've used the Fenton headers and it's a nice set up.
Only problem you will have is trying to find the pipes. You will probablly have to have them made up at a custom muffler shop. I don't think anyone is making the exhaust systems for them anymore. Maybe someone else here knows of a source.
Back in the day Sears and Wards used to sell a Fenton Header kit. The box came with the headers, the heat riser, the exhaust and tail pipes for your particular model, mufflers, clamps and hangers. I installed one on my '60 Biscayne back in '63 and sure wish the were still avalable.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Patrick's in Arizona and some other aftermarketers sell a stainless steel exhaust system, but it is expensive. $675.00
Drew
DrewP #700153 12/02/2010 5:35 AM
National chevy association sells pipes to run with fentons. price was reasonable, but did have to "massage" them a bit to get the passenger side to fit.
50' chevy 3100 shortbed
