6 members (Barney1951, treegrower, TUTS 59, Gray_Ghost, cmayna, UtahYork), 85 guests, and 0 robots.
Topics128,067
Posts1,055,877
Members48,428
#699968 12/01/2010 5:30 PM
I found a 235 but not sure what it from
ser. # 007778IF
block casting #3837004
I know its a 1955 to 1957 but what engine??
Your missing a couple of numbers Dave. Better do a little more cleaning and check that again. The nunbers are the sequence number, the first letter 'F' is code for Flint then there should be two more numbers for the year and a suffex code for the application.
And of course you've already found the casting chart. So the specific year it was assembled should be stamped with the serial number.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Sorry about that, what I found is 007778IF56Y
see if that is better
and thank you for getting back to me
dave johnson #700057 12/01/2010 11:47 PM
That's better Dave, '56 235 w/powerglide.
Ya got a power house there, should be a nice engine for your truck. By the way, what's it going into????
Denny G
Denny G
Sandwich, IL
Dave, You can narrow down, your 1955 to 1957 block,
to a month, day, and year.
The block "date code" casting is near the 3837004.
Something like... C 7 56.
Powerglide would also indicate hydraulic lifters.
55.2 - 57 trucks had 3837004 casting but with solid lifters.
-Tom
1950 Chevy 3100 w/ 1956 235
Thanks for the Info Denny
I have a 1951 3100, I have own it since 1966. and want to make a daily driver. smile
Oilrag #700258 12/02/2010 5:29 PM
Thanks Tom
you say Powerglide, has hydraulic lifters
but that casting # has solids.
How do you know which it has.
Dave J.
"but that casting # has solids"
Block casting code: 3837004
3837004 used from 55-57
007778IF56Y = 1956 engine
All Powerglide engines had hydraulic lifters.
All 56-57 235 car engines used hydraulic lifters
