| | | Forums66 Topics128,065 Posts1,055,868 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 25 | I found a 235 but not sure what it from ser. # 007778IF block casting #3837004 I know its a 1955 to 1957 but what engine?? | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Your missing a couple of numbers Dave. Better do a little more cleaning and check that again. The nunbers are the sequence number, the first letter 'F' is code for Flint then there should be two more numbers for the year and a suffex code for the application. And of course you've already found the casting chart. So the specific year it was assembled should be stamped with the serial number.
Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Dec 2006 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 25 | Sorry about that, what I found is 007778IF56Y see if that is better and thank you for getting back to me | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | That's better Dave, '56 235 w/powerglide. Ya got a power house there, should be a nice engine for your truck. By the way, what's it going into????
Denny G
| | | | | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 | Dave, You can narrow down, your 1955 to 1957 block, to a month, day, and year.
The block "date code" casting is near the 3837004. Something like... C 7 56.
Powerglide would also indicate hydraulic lifters. 55.2 - 57 trucks had 3837004 casting but with solid lifters.
-Tom
1950 Chevy 3100 w/ 1956 235
| | | | | Joined: Dec 2006 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 25 | Thanks for the Info Denny I have a 1951 3100, I have own it since 1966. and want to make a daily driver.  | | | | | Joined: Dec 2006 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 25 | Thanks Tom you say Powerglide, has hydraulic lifters but that casting # has solids. How do you know which it has. Dave J. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | "but that casting # has solids" Block casting code: 3837004 3837004 used from 55-57
007778IF56Y = 1956 engine '56 235 w/powerglide
All Powerglide engines had hydraulic lifters. All 56-57 235 car engines used hydraulic lifters
