6 members (Otto Skorzeny, ShopRag, Gdads51, 55shaker, 78buckshot, Woogeroo), 147 guests, and 3 robots.
Topics128,268
Posts1,058,382
Members48,485
#698287 11/25/2010 11:40 PM
I spoke with an older gentleman last night about a 235 he has for sale, he tells me it has a Monza four speed bolted to it.
I asked him if it needed an adaptor plate to connect, and he told me no, its a straight bolt on change.
Has anyone ever heard fo this ?
I don't know the year of the engine but am going to look at it on the weekend.
1946 Chevy 1/2-Ton
More pix on Photobucket
Sometimes I forget where I left myself....
I think Monza used the saginaw 4 speed just like the vega did , they also used them in a lot of other cars also. it should be a direct bolt up .
The Saginaw 4 speed was popular in the early to mid sixties Chevy full sized cars-Impala and such. Good transmissions;bolt right up to the 3 speed bellhousings,same clutch splines,and there's an adapter kit available to hook one up to a Torque-Tube drive. I've also heard rumors of using the overdrive output shaft and tailshaft housing,to give you a 4 speed with overdrive. that'd be the best of both worlds!
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
Do you know who carries the adaptor setup to connect this to the '46 torque tube driveline ?
Is the overdrive unit a saginaw part ?
Or should I be looking for something else?
1946 Chevy 1/2-Ton
I guess I should have also added, the same guy has a complete '55 chassis that I could use the drivetrain out of too, would this be an even better option ?
Is the rear end the same width or is it not useable.
Thanks for all the great advice!
AM
1946 Chevy 1/2-Ton
3B Offline
Hy andy46, there are actually two totally different 55 chassis, the parts from a 55.1 or "A" would be easier to adapt than those of a 55.2 or "B" series, hope that helps.
I think this is actually the second series chassis, but not 100% sure, but thats a good question, going to have to phone the guy now and find that out.
Andy
1946 Chevy 1/2-Ton
Andy,
You will find your choices are really limited if you are keeping the torque tube driveline. A call to Patrick's in Arizona is a must. I believe he has a kit for using the saginaw 4 speed with the torque tube. However, the 1946 has a different bellhousing bolt pattern than the later trucks. The deco and prewar trucks had 3 extra holes drilled in the bellhousing for the brake and clutch pedals. A later 47-54 bellhousing will bolt to the saginaw transmission, and your crossmember with no modifications, but it will not bolt to your brake and clutch pedals. I believe Jim Carter sells an adapted bellhousing for this purpose... to put a later transmission in an earlier truck and bolt the brake and clutch pedals back to the bellhousing like stock.
Thanks for the advice guys, I should have stated earlier, the 46 truck I have already has a '54 motor in it now.
So I'm thinking of swapping in a '55 motor with the Monza Saginaw four speed and maybe using the open rear end from the donor chassis if I get that too.
Or sticking with the closed 46 driveline.
Not sure which route to go with.
Andy
1946 Chevy 1/2-Ton
The bellhousings are interchangeable to the motors. Any 1937-1959 216, 235, or 261 chevy bellhousing will bolt up to any 1937-1959 chevy motor. The same is true with gmc motors and bellhousings from 1939-1959. In fact, the gmc bellhousings are interchangeable with the chevy bellhousings.
The trick is to use the bellhousing that fits your chasis the best. In your case it will probably be the 1937-1946 bellhousing on the 1955 motor. This will allow you to run the stock transmission and torque tube behind the newer engine.
If you want to change transmissions you have a few options.
1. Use an adapter plate between the bellhousing and transmission. This works extremely well when putting a T5 behind a stovebolt with the early 1937-1946 bellhousing.
2. Get a modified 1947-1954 bellhousing. Ok, it might actually be 1948 or 1949 and later to have the correct bolt pattern for a muncie or saginaw 4 speed. The 1947-1954 bellhousings will bolt into a 1946 frame with the 1946 rear motor mounts and crossmember. These bellhousings will not bolt to the clutch and brake pedals... unless they are modified.
3. There are many other options but they all require more fabrication.
Anybody got more info on the closed drive adapter for the rear of the Saginaw 4spd trans? Is that a Patricks deal. Or something to look for at a swapmeet or junkyard?
Thanx for the help,,,,,,,,
Marty, I believe that's a Patrick's deal.
Thanks for all the info on this, good stuff, now just need to pick a route, and I'll be on my way!
Thanks again!
1946 Chevy 1/2-Ton
Thanx Bigdaddy, Ill check out Patricks. Happy Truckin.
I did buy the engine and the trans, but still not sure I'm going to go that route.
As an aside the rolling chassis he has is for the later '55 pickups, and is a complete chassis with a 235 and trans in it,
If anyone wants it, he wants $200. for it complete, a pretty decent deal for a complete rolling chassis.
If anyone wants it PM me, and I'll give you his number.
Thanks guys.
1946 Chevy 1/2-Ton
